1992 Ranger w/5.0L swap, OEM wiring harness help
JER-BEAR-ID
Klamath Falls, Oregon
Ford Fuckin Ran
Hi everybody,
I'm new to posting on these forums, so if this is in the wrong spot or something, I apologize in advance... Anyhow, I came across a 92 ranger someone had swapped in a 5.0L out of a 1993 foxbody... They put a carburetor on it so I won't have to worry bout wiring the efi... But the truck has electric windows and door locks on it and to be honest it would be nice to make everything work, ex. Wipers, lights, locks, windows, heater and eventually even the a/c and cruise control... I'll worry about the last 2 later though... Whoever had the truck before me ripped out most all of the wiring under the hood... the main plug in the firewall is still there and I came across another ranger a guy was parting out and purchased the pigtail that goes under the hood... with all that being said, I guess I'm looking for a diagram or schematic of what each of the 50+ wires goes to so I can try and hook up what I feel to be necessary to run and drive comfortably.... Any and all help is greatly appreciated!!!
Thanks in advance,
Bear
P.s.
Oh and by the way it's 4×4 and I'm pretty sure it has a ford AOD Trans and the factory ranger tcase....
franklin2
1,769
Virginia
The ranger you took the wiring out of. What year was it?
The engine is running correct? All it needs is one key on hot wire to the ignition system. By the way, when they changed it over to carb, what ignition system did they use during the swap?
JER-BEAR-ID
Ford Fuckin Ran
If I remember correctly it was a '92 Ranger, that the harness came out of... Both trucks had 4.0L's from the factory... The 5.0L seems to run pretty good, all of the gaskets are new and the plugs were barely threaded in the holes and the wires were all on the wrong spots, no where near the 5.0L or the older 302 firing order, I'm pretty sure I'm the first one to hear it run since it was rebuilt... I'll take a few pictures of it this afternoon and post them... I'm not 100% sure on the brand of distributor... They didn't put a msd box or anything like that in there...
JER-BEAR-ID
Ford Fuckin Ran
I know it won't take much to make it run but I'd like to make the power windows and locks work along with the heater, wipers, guages, headlights and tail lights... I'm gonna try and make it a daily for my ol'lady...
franklin2
1,769
Virginia
Looks like it has a aftermarket 1 wire HEI distributor on it. A hybrid of GM style on top, and the bottom machined to fit the Ford. They work well.
This diagram has the fuel gauge wire colors, the starter and ignition switch. Most of these stuff in this diagram you will not need.
franklin2
1,769
Virginia
Here are the lights, heater controls, electric locks, electric windows, etc.
franklin2
1,769
Virginia
Here are some power distribution diagrams.
JER-BEAR-ID
Ford Fuckin Ran
Wow! Thank you sir! You are a bad ass!!!! And very much appreciated!!! Now, I have to stop procrastinating on the wiring and just get it did! I've been dreading this part since we bought the truck about a year ago... hahaha, but for $900 I couldn't pass it up! Thank you again! I've been trying to find these for a couple of days, not solid but looking here and there...
