sgtsandman
Aircraft Fuel Tank Diver
- Mar 11, 2017
- 12,682
- Aliquippa, PA
- Ranger XLT/FX4
- Engine Size
- 4.0 SOHC/2.3 Ecoboost
- 2WD / 4WD
- 4WD
- Total Lift
- Pre-2008 lift/Stock
- Tire Size
- 31X10.5R15/265/65R17
I spray them and the hinge pins where the hinge comes together with white lithium grease.I don't have any jacks tall enough but stacked some fire brick under it and used some wood shims to hold it up tight and still can't get it to align with that door latch, no matter what it still has to be shut briskly (although not quite as much as before) with an upward lift for it to latch, and the top is still not as high as it should be after closing. I did nothing to the inside hinges, and the door side hinges have no adjustment (unless it would be to add a washer on the door pin under the door side hinge to ride it up a bit). ATM I'm not certain which way to tweak it onward so I'll think it over for a while
Also I wonder about that wheel on the bottom hinge that locks it in at certain points, is there anything to help that such as grease or anything?
