LandonRobinson
- Jun 14, 2018
- 0
- McMinnville Oregon
- Ford
- Engine Size
- 2.3
About five days ago I noticed that I was starting to leave little oil puddles everywhere I was going, today I crawled under there and looked and sure enough drive shaft seal for the front differential is clearly leaking all over the place.
From the looks of it I just need to unbolt the drive shaft from the axle housing, then break loose whatever big nut it has and then the input shaft should slide out shouldn't it and then pry the seal out and put a new one in?
My only other question is what kind of oil does the front differential use?
