1996 B2300 2wd Front Suspension
WayCool1421
Charlotte NC
Mazda B2300 2wd
I have a 96 B2300 which I know is just a Ford Ranger. She has 217,000 miles. I am wanting to replace most of the front suspension parts. I am a experienced mechanic but have never messed with suspension parts outside of shocks/struts kind of stuff. The truck feels supper loose especially when hitting a pot hole. Just seems wore out. lol. Anyone know where I can get parts from or have a part list suggestion. Again not really familiar with suspension. My searches turn up only ball joints, camber caster bushings. I am looking more for complete upper lower control arms etc. Any help or direction on what all to replace, or not replace is welcomed.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,662
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You probably have Twin I Bean front suspension.
I suggest looking at the Tech Library on the site and poking around. It will give you an idea of what you're dealing with.
These trucks tend to drive a bit different then what you may be use to.
tinman_72
140
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
Yes, 2WD in '96 was twin I-beam.
Ball joints, radius arm bushings, axle pivot bushings, and sway bar bushings are your normal wear items for front suspension
WayCool1421
Charlotte NC
Mazda B2300 2wd
So Tinman_72, you would not replace the radius arms themselves or the sway bars, just bushing??
tinman_72
140
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
Not unless they are damaged.
