1996 ranger 3.0 4x4 transmission compatibility
4thhouse
Pennsylvania
Ford ranger
Just recently bought 96 Ford ranger xlt 3.0 4x4 and the transmission was completely disassembled. Have any extremely hard time in my area finding a transmission, the closest thing I found was a 98 3.0 4x4. What years were just bolt in and is there any other vehicles with this trans
8,372
Welcome to TRS :)
Since you have a 1996 4x4 the speed sensor is on the transfer case so you don't need that on replacement transmission
So you can use a 3.0l 4x4 Automatic from 1995 thru 2008(last year for 3.0l)
3.0l Ranger or Mazda B-3000 4x4 will plug and play
You have a 4R44E model now, but a 5R44E will also work for you, just has 2 extra sensors on the outside that won't be used
Needs to be from a 3.0l to match engine bolt pattern
And a 4x4 so transfer case can be bolted on
The 1998 3.0l 4x4 is a 4R44E and will plug and play in your 1996
4thhouse
Pennsylvania
Ford ranger
Thanks appreciate it, and the 5r44e is a 5 speed right, and 4r is a 4 speed
8,372
No, both are EXACTLY the same transmission internally, Ford used Computer software added a 5th gear to the 4R, so Ford could advertise it as a 5R because it was now a 5-speed, the new "gear" was between the old 1st and 2nd
If you put a 5R into a Ranger with 4R software it will work as a 4R
If you put a 1995/1996 4.0l 4R into a 1998-2000 4.0l it would act like a 5R, 5-speeds, because 1998-2000 4.0l computer has 5R software
But in 2001 Ford also added 2 external sensors required by the 2001 and up 5R software
This is when all Ranger computers got the 5R software
So you can't use a 1995-2000 4R in a 2001-2011 Ranger, because they don't have the extra sensors
But YOU CAN use a 2001 to 2011 5R in a 1995-2000 Ranger as a 4R, or 5R in the case of 1998-2000 4.0l Rangers
5R software turns on OverDrive whole still in 1st gear, this adds a 5th Ratio(gear), so a new 2nd gear
Automatics have "Ratios" not specific gears like a manual transmission
They have planetary gear sets that can do multiple ratios
4thhouse
Pennsylvania
Ford ranger
Appreciate your time informing me, glad I found this site love rangers have two now bought my first ranger a 1997 10 years ago had to literally do bare minimum to it over the years still running strong, me and my son are getting ready to try to throw in a 2JZ in the in it,
8,372
Toyota 2JZ?
Its an inline 6 and 31" long, just pulleys no cooling fan..................and 27" tall
The 302/5.0l OHV V8 barely fits at 27.5" long, and 21" tall
Gonna need some custom firewall and grill work to squeeze that in, unless you go air cooled, lol
Might get away with a 4" body lift for height issue, its 18" wide so you may be able to set it down lower in engine bay since you need custom motor mounts anyway
