1998 Ranger Fuse Box/Wire DIBACLE!
Drag Week Splash
Kentucky
Hi,
wrapping up the list of to do's before I embark on 2022 HOTROD dragweek with my 302/c4 swapped Ranger.
The last bit of work is all wiring!
The wiring on this truck is a mess (previous owner was a volunteer fire fighter)...
Half of my fuse block (In cab) is dead.. no power..
What wire or wires power the fuse block...
My plan is to simply power the fuse block so I can get the headlights, turn, park, tail lights going...
I only need these lights to pass tech!
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,573
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I don't have a wiring diagram for that year...
you will need a hot at all times source and a key on source. They most likely originate from the underhood fuse relay center.
ericbphoto
Overlander in development
16,739
Wellford, SC
3.0L
6"
Are you sure that the dead parts aren't the parts that should only have power when the key is on?
franklin2
1,772
Virginia
Bronco II
The outside lighting should work all the time.
James Morse
1997 XLT 4.0L 4x4 1999 Mazda B3000 2wd
974
Roanoke VA
1997 and 1999
XLT 4x4 & B3000
4.0L in XLT, 3.0L in B3000
31x10.5-15 K02's on the Ranger, 235/75R15 on Mazda
The perfect is the enemy of the good.
Yeah and loud insistent chimes if you leave the headlights on, which is nice.
