SOLD! 2 1/2” drop pitman arm
tw205
Bronco II Rancher.
983
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
I have this drop pitman arm to get gone. Got it from an 85 BII. My guess is it’s the one they sell with complete lifts but I’m not sure. Should fit many trucks not just BII Ranger Explorer. I think they consider it a 2 1/2 inch drop. Pictured by a stock BII arm. $35
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,543
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Per forum rules... you have to post a price.
I'm sure someone can use that...
tw205
Bronco II Rancher.
983
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
My bad. Will get right on it.
rang-a-stang
56
Boise ID/Camarillo CA
3"
31x10.50R15
Any chance you still have this? (please say yes, please say yes)
tw205
Bronco II Rancher.
983
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
28
Oregon
Ford Bronco II
I do have one. It's a brand new Rough Country 6601. Came with a 4" lift kit I bought.
Looks like they're $49.95 with free shipping from Rough Country, so I'll sell this for $25 + shipping.
rang-a-stang
56
3"
31x10.50R15
DANGIT!! I got impatient and went the Fleabay and grabbed one late last night. I appreciate you digging that out, Bronson with Bronco and I would have 100% grabbed it if I wasn't so immature/impatient!
28
Oregon
Ford Bronco II
No problem. Glad you got one. What are you building up?
rang-a-stang
56
3"
31x10.50R15
Nothing Juicey. My son's 86, standard cab, short box, 5speed, 4wd, v6 has 2" lift coils on the front and has been EATING it's front tires. Alignment shop says toe and camber are perfect when sitting on the rack (although caster is almost 0). Poking around on here, I started reading around about the pitman arm/steering angles and found we have a stock pitman arm so my drag link is at a fairly steep angle. When I measure to see how far out of level it is, it's about 3" high so hopefully a 4" drop pitman will get it closer to level and save some tire wear and tear? We will eventually SAS the front and it might get a tiny bit more lift so I am err'ing on the side of too much pitman arm rather than not enough.
28
Oregon
Ford Bronco II
Sounds like a fun project! Hope the pitman arm solves your problems and saves the tires.
