2.3L ('02-'11) 2.3 Duratec water pump
BossP351
4
Silverdale WA
Greetings and everyone may already know this solution but after a long day of bloody knuckles I soaked it in PB Blaster and slide hammer made it easy.
Jazzer
458
Indianapolis
That would have made mine a lot easier. :unsure:
BossP351
4
Silverdale WA
Yep! I also bought the hose assembly with the infamous plastic tee but it checks out OK. I probably should replace it now @ 150k.
snoranger
Professional money waster
ASE Certified Tech
TRS 25th Anniversary
13,785
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
That looks like fun.
The BOB
Phoenix Arizona
Ranger 2.3
I am going to change out the water pump soon and that looks like the best way to do it.
A few questions
What size slide hammer did you use? Is it a very small one?
I see that you took out the radiator to give you more room. Did the A/C condenser get in the way of the slide hammer?
Thanks for the help.
BOB
pjtoledo
3,061
Toledo Ohio
Fords
3.0 2.3
I tapped on the bolt hole ears to rotate it.
with the thermostat removed you can hit the backside of the pump with a long bolt or whatever.
it seizes in due to corrosion.
