2.3 engine runnig rough
89ranger2.3
inman sc
2.3
I have a 89 ranger 2.3 5spd and when it idles it sounds like it has a camshaft in it but it doesnt ive replaced everything but the egr valve and still no fix can someone help me please
fordman4x492
berwick louisiana
5.oh 3oh2 v8
it sounds like a fuel delivery problem. the 88 model had the same problem. it would run rough but what is causing it to do that is unknown.
fordman4x492
berwick louisiana
5.oh 3oh2 v8
i also heard something about the fuel delivery problem being caused by a faulty fuel shut off swich. i would try to change that out and see if it helps.
fordman4x492
berwick louisiana
5.oh 3oh2 v8
if you have gunky buildup in your throttle body it can also cause it to idle rough. check your throttle body and if it is realy dirty take it off and clean it with some carb cleaner. olso check your o2 censor
fordman4x492
berwick louisiana
5.oh 3oh2 v8
it runs normal when you tap the gas right? if so adjust your idle it might be to low
3,614
define "everything" with an itemized list.
89ranger2.3
inman sc
2.3
i have replaced the fuel pump injectors throttle position sensor idle air control map sensor plugs wires egr position sensor
3,614
O2 sensor?
89ranger2.3
inman sc
2.3
and replaced the o2 sensor
3,614
hmm. But it runs ok off idle? Check your timing.
89ranger2.3
inman sc
2.3
yea it runs fine jus idle it sounds like a v8 does with a big cam in it
3,614
check the timing, see if its off. If not, start worrying.
89ranger2.3
inman sc
2.3
thanks do you know what the timing should be set at
fordman4x492
berwick louisiana
5.oh 3oh2 v8
does it have a distributer or coil pack. most likely a distributer right?
89ranger2.3
inman sc
2.3
a coil pack
