2.3 harmonic balancer
SGE
8
Pennsylvania
Hello all
I’m trying to change a timing belt on my ‘97 ranger with the 2.3.
I’m having trouble getting the bolt out. My impact won’t move it
Anyone have any imput?
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
brace a breaker bar against the top of the drivers side frame rail or the bottom of the passenger side frame rail then bump the starter, it'll come out...
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Pull the fuel pump relay first for the love of god.
snoranger
Professional money waster
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I've been adventurous... trying to spare people other similar adventures.
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
Good call, pedal to the floor for clear flood mode should stop it from running as well.
SGE
8
Pennsylvania
Belt was broke so I diddnt bother with the relay. The breaker bar trick worked! Thanks!
Now the belt is on but I can’t get all 3 timing marks lined up at the same time with the belt on. Do they need to be perfect?
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
Yes, if I remember correctly you need to start it a tooth off before releasing the tensioner because the tensioner moves it a tooth. Someone make that into a coherent sentence I'm tired...
snoranger
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Allow me to translate from Dirt-enese to English...
Yes, the timing marks must line up. Sometimes you have to line one or more of the marks up a little shy of dead on and allow the tensioner to pull the marks into place. You may have to try it a few times to get it dead on, if it’s your first time doing a timing belt.
SGE
8
Pennsylvania
Yes this is my first time. I’ve tried it several times but one or the other is off a bit. I’ll keep trying until i get it right. Thanks
snoranger
ASE Certified Tech
13,654
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
It’s been a long time since I did a timing belt on an old 2.3l...
IIRC, there is a triangle and a diamond on the pulleys. Make sure your trying to line the correct symbol up. (That may only be on the older ones)
SGE
8
Pennsylvania
Ok thanks
