2.3 issue
scheff
monroe MI
2.3
I have a 90 2.3 4x4 ranger I have replaced the whole cab and have hooked everything up correctly and have been driving it for about 2 weaks. yesterday the check engine light came on and about 1 mile later the truck died. it started back up about a hour later. the coolent is full the temp gauge don't work. I was driving it today and the check engine light came on I turned the truck off and tuned it back on the light went away for a few miles then came back on. I have replaced the tps, both coil packs, pulgs wires, it has a junk yard ecm in it. this problem is getting worse. does anyone know whats going in? I need to know asap its my only car. I am open to all suggesting's and comments. thanks
Mark_88
240
Ontario, Canada
Dordge
3.3 Fuel Injected
Love Thy Neighbor
You should be able to pull the codes to see if there is a problem with one or more sensors.
There is a tech article in the library that tells you how to pull the codes...sorry, I don't have a link to it...but if you use the search at the top you can find it easy enough.
