2.3 motor mounts interchange?
rab
merkur
I have a 83 ranger was a 2.0,i swapped in a
2.3 and over winter im doing a 2.3 turbo swap.
Are there any upgraded motor mounts i.e. poly
Are all 2.3 motor mounts the same 83-92,are
certain year mounts better?
Kenneth S
7
San Antonio, Tx
2.3
Stick with the motor mounts your 83 has, in 1988 they changed to a "hydraulic" motor mount which are junk, and more expensive. Don't know of any poly type mounts.
rab
merkur
Here is a link to a guy that made a cheap set out of hockey pucks, my 83 mounts look different, from the pics it looks like I would possibly just need a cross member bracket from a later model ranger to make this work, can anyone comment on this?http://www.turborangerforums.com/showthread.php?t=5683
Kenneth S
7
San Antonio, Tx
2.3
That would work, but I'd weld a nut underneath rather that a bolt, makes it easier pull, or put the engine back in (unless you like pulling the frame mounts also).
Mikel89us
5
2.3L (2.5L soon)
You can also buy a pair of a-arm bushings, from a mustang or something, and make your own motor mounts. As far as I can tell there are no aftermarket motor mounts for any 2.3l... If there are, I have never seen them. I used ploy sway bar bushings for mounts once, they worked.
rab
merkur
ok my 83 mounts look different, so just to make things clear sometime after 83 they added a bracket or changed the engine crossmember to run a different mount for a 2.3?
so i can just bolt the mount to my 83 crossmember? or do i need a new crossmember?? or what, to make this work?
if i just have to add a bracket can these still be bought new?
rab
merkur
also does anyone know of a cheap upgrade/more solid 2wd 4 or 5 speed trans mount?
Mikel89us
5
2.3L (2.5L soon)
If I'm not mistaken, Noone ever took 2.3's serious.. The people making big hp in a 2.3 are using custom, or solid mounts.
Kenneth S
7
San Antonio, Tx
2.3
if i'm not mistaken, noone ever took 2.3's serious.. The people making big hp in a 2.3 are using custom, or solid mounts.
x2 ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
The 83-87 used the same motor mounts, in 88 they changed the motor mounts on the frame (the frame itself is still the same) along with the motor mounts.
rab
merkur
Thats what i was thinking after looking at a couple of pics, does anyone know of a place i can buy these 88-up frame brackets from?
rab
merkur
well guys i have not found the brackets i need for the newer 88-up mounts, which i want to run along with the hockey pucks ( again here is the link.... http://www.turborangerforums.com/showthread.php?t=5683 )
So for now im just going to go with the wedge style, well if u go to rockautos web site they offer different mounts for 83-84 2.3's vs 85-87 2.3's, the 85-87 are much cheaper and if they work i want to run those for the timing being untill i can find the newer engine brackets i need.
So does anyone know if the 85-87 wedge style brackets will work on my 83 before i try ordering a set.
TheeFinalGun
995 Hurricane road New Market Alabama
I appreciate this thread, I have an 85 ranger and can't get a new 2.3, so I'm stuck with a newer model 2.3 mounted on a Mazda trans (5 speed toyo) I have to knock out a spot for the fuel pump cause they changed the cast of the block but kept the location for the fuel pump available, just in case, I suppose. I really just need to know if I might place a newer 2.3 engine from a 92 and use the same motor mounts feom the 85......?
Junk Collector
Truck of Month
4,846
Rapid City SD
Should be able to reuse your motor mounts.
Kenneth S
7
San Antonio, Tx
2.3
The motor mounts should bolt right up.
