schlutzer
- Aug 13, 2008
- Reaction score
- 0
- Make / Model
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Manual
- 2WD / 4WD
- 2WD
Okay so my truck has recently had a lot of issues that i have since fixed it has:
All new vaccum lines
new fuel and air filters
new in tank fuel pump
fresh gas
spark plugs/wires
distributor cap/rotor
I have good compression 150psi on each cylinder
but when I drive it sucks, NO power. When I start the truck its fine normal power and only a slight hesitation when you rev it, for about a minute then its horrible. Also if I hold the revs at what should be ~1500 it goes up and down from 1300-1600, will do that no matter where I'm holding the pedal but idles totally normal at 900
If I take it up high in the rpm before the shift it sputters and backfires for a minute and i have to take it out of gear. but other than that it just has no power.
also after driving if i stand right by the drivers door I can smell gas. but there are no leaks, the tank isn't leaking either as I had the bed off to change the pump and checked about 5 times.
I've done sooo much work to this truck I just want it running good again! Sorry for the long post! And its an 88 2.3 5spd
__________________
fresh gas
spark plugs/wires
__________________
