2.7/3.5 EcoBoost to stock 4x4 driveline?
Lee daMet
Florida
Ford/Ranger
Factory for now
If you don’t have anything good to say, shut the hell up!
Has anyone put a 2.7 or 3.5 twin turbo in a ranger yet? I am seriously thinking about it. Not sure what would have to be cut out of engine compartment, if anything. I think it would be super cool setup. not sure about how it would bolt up to present driveline. Curious about electronics to make it work also. I’ve got a 94 4.0l with 246,000 on the clock. It’s tired. Was well abused before I got it. I want to make her clean and reliable. Thanks for any advice.
sgtsandman
Aircraft Fuel Tank Diver
12,698
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Not yet that I'm aware of. There was talk of trying a 2.3 Ecoboost but chatter on that died down.
8,372
You can look here to see what Rear wheel drive(RWD) vehicles they came in: https://en.wikipedia.org/wiki/Ford_EcoBoost_engine
Then see what RWD drive train was available, i.e manual/auto, 2wd or 4x4
No, no 1983-2011 Ranger drive train would match up, although the axles would be useable
Width is the big thing in Rangers on engine swaps
The 302(5.0l) was popular swap because its only 19" wide, and they barely fit
When you go to Double Overhead cams you get up to 30" pretty quick, lol
And then you are having to move the steering and putting exhaust outside the frame, and of course no heater box
Ranger850
Doesn't get Sarcasm . . .
4,695
Tallahassee Florida
Stock 2"
Stock
Somebody on here swapped a 2.3 ecoboost into his ranger, bolted right up to his trans. Another guy started the 3.5 ecoboost swap, had to redo his steering. Not sure which trans he was planning to use if he has even got that far, but his motor was from an F150
Stay away from the 2.7. They are cheaply manufactured garbage. The only way I would even consider using one for anything was if it was
A) A later build unit (2019 or up) that had a real oil pan gasket
and
B) Free.
And when I say "stay away" if you are on Earth and that engine is in the Proxima Centauri system ~4.3 light years away, you are still too close.
sheep herder
1,024
sheep pen
If it ain't broke, break it.
and
B) Free.
:icon_rofl:
17,910
SW Iowa
Somebody on here swapped a 2.0 ecoboost into his ranger, bolted right up to his trans. Another guy started the 3.5 ecoboost swap, had to redo his steering. Not sure which trans he was planning to use if he has even got that far, but his motor was from an F150
FIFY
8,372
The 2.3l ecoboost used the 2.3l Duratec/Mazda L bolt pattern so a 2002-2011 Ranger 4cyl trans would work, but............they never came in 4WD models
2.7l/3.5l are different
sgtsandman
12,698
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
and
B) Free.
So, you don’t like the engine?
don4331
1,352
Calgary, AB
5.3
While the OP doesn't say if his '94 is 4x2 or 4x4, he will need a M5OD-R1 from '02 up Ranger as minimum for a 2.x Ecoboost swap. So, if he had a 4x4, he could pull the appropriate pieces from his existing transmission (output shaft and housing) and build a transmission which would allow him 4x4 with the Ecoboost.
Extra work, yes but all stock Ford parts.
ericbphoto
Overlander in development
16,648
Wellford, SC
6"
We aren't seeing major mechanical issues with them yet, but the minor ones I see cropping up, like the leaking non-reusable oil pans, make me wonder very hard about what other cost-saving corners were cut during the design and production phases.
ericbphoto
16,648
Wellford, SC
6"
Non& reusable oil pan sounds like a bad idea to me. When you think about it, a majority of oil pans never get removed. But if you do have to remove it, why should it be a disposable item? That's just crazy.
8,372
The OP wanted 2.7l or 3.5l engine, so different bellhousing pattern than the 2.3l Duratec or Ecoboost used in Rangers
Yes you can convert an M5R1 from 2wd to 4wd, and visa versa, by swapping tail shafts and tail shaft housings, its not simple but certainly do-able
The issue with the oil pans is that the are sealed with this new TA357 RTV sealer and no gasket (until mid 2018 MY when someone figured out how to get their head out of their ass).
The sealer sticks hard to most things, but requires near surgical cleanliness and incredibly precise surface prep to actually seal anything. If you don't prep the surface correctly you have a plastic pan glued to a metal block with sealer that will leak like a sieve. The oil pans themselves also have to be prepped, which is done at the factory, and they can't have the sealer cleaned off and be re-prepped because they are plastic. This means if you have to remove one it can't be reused.
Also, the TA357 is so sensitive that touching the sealing surface of an unused oil pan with your bare skin ruins the adhesion promoter and the pan is junk.
