2.8 bogs and won't go over 58 MPH
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,736
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
I rebuilt the carb on the 2.8L in my girlfriend's son's 1984 Bronco II and had the thing running pretty good.
Now it starts hard and occasionally backfires through the carb when starting, stalls when coming to a stop, and bogs down and doesn't want to go over 58 MPH.
I re-set the idle mixture screws and adjusted the fast idle screw so it doesn't stall when I stop, but it still bogs down while I'm driving it. It doesn't drop off when I give it gas, it just doesn't seem to have any power like something is holding it back. It does run a little better if I let off the gas a little.
Someone swapped a Duraspark ignition on this thing before we got it.
Any suggestions?
alwaysFlOoReD
5,096
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Jim Oaks
Administrator
Supporting Vendor
8,736
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Thought about that. Having trouble getting to the bolt to loosen the distributor. There isn't much room back there.
I forgot to add that I noticed the vacuum line from the distributor run to the vacuum-T on the back of the manifold, not the carb.
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
The vacuum advance normally runs to the manifold.
If its backfiring out the carb that sounds like timing to me. Unless its more of a cough then a backfire, if thats the case that generally means its starving for fuel.
Jim Oaks
Administrator
Supporting Vendor
8,736
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
May
Be more of a cough and not that often. I thought about timing, but I don't understand how the timing was ok and now it's not. Also considered plugs and wires.
fastpakr
2,834
Roanoke, VA
I'd definitely want to put a light on it and see what the timing is doing.
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
May
Hows the float level? Any vacuum leaks at the carb base?
Jim Oaks
Administrator
Supporting Vendor
8,736
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Finally got around to doing a compression test on this thing. Did it with the engine cold and all of the plugs removed.
Didn't try to figure out exact psi. Just note the closest reading in 5 psi incriments.
Results:
#1. 75
#2. 75
#3. 90
#4. 75
#5. 90
#6. 85
It's been my understanding that a healthy engine should be a minimum of 100 psi on each cylinder.
Haven't tried adding oil to the cylinders and retesting yet.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Results:
#1. 75
#2. 75
#3. 90
#4. 75
#5. 90
#6. 85
RIP 🙏🏿
AndyB.
142
Cincinnati, OH
Time for a leak down test to find out if you’re doing rings or valves.
Wide open throttle during compression test, right?
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Was cranking speed good...
Did each cylinder get the same revolutions...
You sure you had a good seal on the tester...
Was the throttle blocked wide open...
Jim Oaks
Administrator
Supporting Vendor
8,736
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Ok, used an oil can to squirt some oil in the cylinders. Can't say that they all got the same amount, and I couldn't get any into the #3 cylinder because there wasn't enough space.
Results:
#1. 125 (originally 75)
#2. 100 (originally 75)
#3. No oil - couldn't re-test
#4. 110 (originally 80)
#5. 135 (originally 90)
#6. 115 (originally 85)
Jim Oaks
Administrator
Supporting Vendor
8,736
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
Fawk.
Throttle wasn't wide open.
Turned it over 8 revolutions for each test.
