2.8l efi swap
BeaterMan
colorado
2.8, 4.6, 5.0
So i'm planning on doing a tbi swap on my old 2.8L and have most of everything i need expect knowing how to plumb the fuel return to the dual tanks. If anyone would have any idea please let me know. My idea was to use a inline frame hi psi pump and then some sort of selector to send return fuel to the proper tank and use that insert for the filler neck on jegs at both necks. thanx - mike
strvger
19
the land of 2 seasons-Winter and getting ready for
2.3
sorry i can't help with your question, but, please do a thread of your conversion with pics as i'm wanting to do something like that with my 2.8 next year.
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
Visit my thread if you want to see a TBI swap on a 2.8 liter strvger.
As for a cheap return lie, get brake line, we did that to my dads, which we didnt get the TBI working right on his due to to much fuel pressure, but the metal brake line costed 6 bucks for a 6ft piece. He used the biggest the part store had as far as inner diameter, its still on his truck despite its not being used.......at the moment.
As for the selector thing your dad has in mind I htink you should do it and post how to do that if somebody else wants to do that to their truck with two tanks. But for the moment I would run one tank to get it running then try for two tanks, just IMO.
My dad wants to see another person do this to their truck. Where you the person that wa going to try a manual tranny computer on the TBI system, and if so post how well it works and what it does my dad wants to know, I think hes getting tired of the carb set-up giving him 10-12 miles to the gallon no matter what he does to adjust it.
BeaterMan
colorado
2.8, 4.6, 5.0
yea the fuel lines will be cake. its just the fact that i got to go buy all this extra stuff just cuz i got two tanks, if i had one tank then it would be a breeze. I did want to use a manual ecu but idk if i would ever find one at the junk yard- i've been hunting for the wiring harness and tbi forever and finally in one day found 2 so i took the tbi from one and the non-hacked up harness from the other.
I got a few other things on the " to do" list like rebuild a 2stroke dirt bike engine i blew up reciently, and get a lil bit more campin and wheeln in before it gets cold but i see this swap taking place before the new year, hopefully if work continues to stay busy.
dangerranger83
54
Lafayette, IN
The only place you may find a manual ecu is the parts store and they want an arm and a leg for it.
enginepaul
12
Northern California
2.8
Used ECU note: This site can help you find the right part number:
http://www.fordecu.com/finditfast/default.asp
Look at the prices, then scout the 'net. I had problems getting the right one until I knew the correct part number (the one in the truck when I bought it was wrong). I bought one from someone here on the list and my truck barely ran. A wrong one from the junk yard allowed me to run, but not pass smog in California. I finally found the correct number and all is well. Yours may run with whatever you have laying around; performance may vary.
I suspect many Rangers get converted to DuraSpark or get junked because of the computers.
About the only thing to add is don't touch the contacts with your hands or anything as it may damage the circuits.
BeaterMan
colorado
2.8, 4.6, 5.0
After alot of research i have found that since i dont wana use a in-tank pump i will need to run my lines from each tank to the selector switch for efi then run a line to a low psi pump then into an accumulator and then into the high psi pump and up the the fuel inlet.
I found an awsome old bronco web site that has most of this stuff relative cheap and since the older broncos used two tanks and alot of people have been doing efi with then, I see no reason why I will not be able to do this.
