2.9 => 4.0 donor transfer case question
uss_essess
Anchorage, AK
2.9l
I am looking to put a 4.0l ohv in place of the blown 2.9l in my 1990 Ranger. I have found another 1990 Ranger on the cheap with a running 4.0l (and bad transmission.)
Both my Ranger and the possible donor are 4WD automatics, but mine has the electronic transfer case and the donor has a manually operated transfer case.
Is this still a good choice for an easy swap, or will the difference cause problems? Thanks in advance for any help!
That other Ranger is a wonderful choice of donor for your truck. Just keep your working trans, use everything else from the other truck.
uss_essess
Anchorage, AK
2.9l
Thanks ADSM. I will have to remember to give you more reputation once I have spread some around a little. Just to clarify, I would like to keep my electronic transfer case as well. Is that easily doable?
Is there an advantage to switching to the manual transfer case?
snoranger
Professional money waster
ASE Certified Tech
13,677
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
You can use either T-case. The manual is preferred because it will never let you down. Just pull it into gear and go.
