2.9 Oil Filter Thread Insert
RustyDusty
14
California
Last two times I changed the oil on my 1987 ranger the oil filter thread insert came out with the old filter. Both times I had a really hard time getting it back in far enough without marring the threads. If it doesn't screw in far enough then the filter gasket doesn't make contact with the block and the new oil will gush out when you start it up. Ask me how I know.. Happened the first time the threat insert came out. Second time I was really careful making sure the gaskets made contact, even sent my boroscope camera up there to see if there was a gap. There was the first 2 times I screwed the thread insert in. 3rd time I definitely messed the threads up a bit while tightening. The Filter went on but felt sort of stripped, never got super tight. I've been running it and its not leaking but I promised myself I'd pick up a new thread insert before the next oil change and figure out how to properly install it so it never comes out with the filter again. Anyone know where I can buy the insert and how do I install it without marring the threads? Thanks!
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,516
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Chase the threads... use a cut off wheel to make two notches on the insert the use a straight edge tool to turn the insert until seated. Clean up the threads again to ensure filter spins on freely.
rusty ol ranger
2.9 Mafia-Don
7,605
Michigan
177 CID
Ive never heard of this happening
AndyB.
142
Cincinnati, OH
Also, I thought there was an internal hex cut into these that would fit a 7/16” allen socket, but I’m not seeing it picture on the eBay listings. Without that, you could use two nuts, tightened against each other, then run in the bottom but to tighten it down:
RustyDusty
14
California
Good idea, I'll see if I can find some nuts that would fit once I find a new thread insert. I'm still not sure where to find one.
AndyB.
142
Cincinnati, OH
Did you click on the eBay link I posted? There are three separate listings for the part.
RustyDusty
14
California
Sorry, I totally spaced on the rest of your comment after reading the idea with the two nuts. I'll purchase the one you linked to and use it to find some nuts that fit so I'll be ready for the next oil change. I appreciate it!
