2.9 Pandoras box
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,515
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I'm with Bobby... something rattled around in there. If it wasn't in there when you took it apart... it passed whatever it was.
Nothing in those pictures say... I'm not gonna make compression. Are you sure you didn't wipe an intake lobe off the cam on that cylinder?
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Is it apart right now? If so flip the cylinder head upside down and put some alcohol in the valve area. If it disappears right away then take a closer look at the ports to see which is wet.
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Good trick. Using that.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Is it me, or does nobody else see an impact mark on the head?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
Maybe I'm seeing something that really isn't there but this looks like a significant connotation leak to me.
33524
Uncle Gump
Token Old Guy
13,515
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I think you're seeing a reflection...
G8orFord
803
FL
4.0 SOHC S/C
Probably, my old eyes couldn't quite get the depth perception tuned in on that pic. I knew it looked almost like a mirror image, but with it being right on the edge of the pic, I wasn't sure. I think I can see it now that I've had a cup of coffee.
Uncle Gump
Token Old Guy
13,515
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
we probably shouldn't trust my eyes... just saying
acsnowrider
138
ARIZONA
FORD RANGER
2.3 EcoBoost
All great testing methods, but I got to add--I got hung out to dry once, when I read 0-2 psi on a compression test, and it was simply because the valves on that cylinder, "were not opening"!
Uncle Gump
Token Old Guy
13,515
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Exactly why I asked if a cam lobe was wiped...
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Gut reaction was cam for me as well.
I agree with G8orFord, though. I can't tell what that notch is.
acsnowrider
138
ARIZONA
FORD RANGER
2.3 EcoBoost
I could be incorrect here, but notches were machined into many pistons, indicating side to point to front of block. This picture. looks like the notch is reflecting on the cyl wall. ??
alwaysFlOoReD
5,125
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Acssnowrider has it. Notch indicates towards front of block. Looks like reflection off cylinder wall.
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Cylinder walls shouldn't be reflective!
