2.9 swap to 4.0 clutch
vonD1025
15
Carson City, NV
2 inch body lift
30”
Ok so everything is done but I can’t find a 4.0 starter block. Anyone know where to get one? Will that fix the alignment of the starter so it works? The mechanic burnt through two starters already because the it won’t line up properly.
8,370
The manual trans 4.0l block plates are hard to find now
Are you using FM or TK trans, or the M5R1?
I think the 2.9l block plate works if still using the FM/TK, just need to open up the starter hole a bit, according to this article: https://www.therangerstation.com/Magazine/May06/40_clutch_swap.shtml
The 2.8l and 2.9l did have starter motor shifting around issues, problem of course is the torque required causes starter to shift, tight block plate hole prevents that
I have read of people using shims INSIDE the bolt holes so starter couldn't shift positions, like coke can thin metal or thicker, on one side
The bolt holes in the starter are larger than the bolts, of course, but too large and starter can shift even if bolts are tight, so shims inside the holes prevent the shifting of the starter housing
vonD1025
15
Carson City, NV
2 inch body lift
30”
I’m not sure but he says it’s not a Mazda transmission
8,370
Then the 2.9l block plate can be used, just need to open up the starter hole a bit, but not too much or starter will shift positions
vonD1025
15
Carson City, NV
2 inch body lift
30”
You think that’s the reason it’s eating starters. He cut the hole to big so it won’t seat properly?
8,370
Maybe, not there but you are :)
4x4prepper
216
Atlanta
If you are eating starters I would suspect maybe you are using bolts and not starter bolts which have a thick shoulder that will snugly fit the holes in the starter. If the bolt is too long the shoulder will bottom out against the threaded hole and not secure the starter.
The starter for the manual is different for the automatic and if you install an automatic starter in an manual or visa versa, you will break them. I proved this to the manager at O'Reilly's by measuring the depth of the nose when mounted and that they were providing the wrong (this case a manual for an automatic) starter for the 3.0. I had this issue too with my 2.8L.
What I have done in the past for bolts that loosened up, despite being the correct ones, is get extra long bolts and secure them where they came out of the back of the housing. Sometimes you have to position the nut, hold it with an open end wrench, and screw the bolt in to secure it.
vonD1025
15
Carson City, NV
2 inch body lift
30”
They cut plate wrong, swapped it out for a 4.0 and it sounds clean and drives like a beast now.
