2.9 tick
2manyfords
Brandon Manitoba Canada
10psi at idle is still kind of low isn't it?
Was the engine completly warmed up when you did the oil pressure check?
I've had a 2.9L loose oil pressure after a few miles down the highway once "everything" was up to operating temperature.
ford_2.8
center,mo
thanks for the response i feel alittle better but im worried about the low oil pressure at idle or is it ok?10 at idle when warm
MAKG
19
California central coast
I'd worry a bit more about the 700 RPM idle.
Spec for a 2.9L is 800 RPM for manual transmission, 900 RPM for automatic. Is the base timing off?
Oil pressure is generally proportional to RPM, so something is a bit off. It's kinda hard to make a system where the pressure falls faster than that. If it's really 15 PSI, it's in proportion.
ford_2.8
center,mo
can you turn the idle up any?
MAKG
19
If you can, it's broken.
2.9Ls have a thing that looks like an idle stop screw. It's NOT that. It's an adjustment for the TPS (should be ~1V with the key on and throttle closed). It won't affect the idle speed for more than a very short time.
Run the self tests and check base timing. There are a handful of problems that can cause incorrect or unsteady idle. Most of them are pretty simple to repair.
ford_2.8
center,mo
well i put oil pump rod and main bearings and it still has low oil pressure at idle?id say 7 to 10 pounds at 800 rpm's
Natedog
5
CA
i didnt even think about the rpm. it holds 40psi at 2000 rpm but at idle about 700 rpm it holds very low like 10 psi
That is probably fine...similar to what I've seen em run at before. What weight oil are you using and what was the ambient temperature at the time?
ford_2.8
center,mo
well today the oil pressue is at 25 at idle/700 rpms at 190 and 60 psi at 2000 so im pretty happy and the tick went away so i guess its good for now unless there some problem areas i can fix before somethin bad happens.
ford_2.8
center,mo
i ahte to bother everyone again about my p.o.s but it started the same thing again it wont hold no oil pressure and the lifters wont pump up so its missen so can someone give me an idea?
rickcdewitt
5
nor-cal
4-0 swap
cold start up tick?
if its like my truck it ticks for less than a minute on cold start up if you dont drive it for a couple days.its more than likely that a little oil is draining back to the pan from the oil passages and your old worn lifters dont like it.combine that with enlarged cam bearing clearance and it takes a little bit to build pressure.the pressure regulator on my truck also ticks loudly im more worried about that as ive heard you can drive a long time with the start up lifter tick.new lifters might help but i wouldnt tear it down unless they were noisy all the time.
ford_2.8
center,mo
there is a oil regulator? mine it dont tick when cold but when it warms up and when it warms up the lifters bleed down im guessing and the the valves wont open so then it wont hit in that cylinder. im just wonderin whats wrong.:temper:
ford_2.8
center,mo
anybody got an idea?
RadDadsRanger
Check spark plugs
Had the same problem with a 2000 Hyundai Elantra 2.0L 4 banger. Checked all over to figure out what was clicking. Finally, while checking the plug wires, I noticed that when I pushed down on No. 1 plug wire with engine running, the ticking stopped. Sure enough, the plug had apparently not been torqued down enough, and it had backed out of the plug hole enough for the compression to blow out around the plug, making the ticking sound. Tightened the plug, and all was fine. Never backed out again.
As MAKG so wisely advised me once, don't overlook the obvious before digging too deeply and randomly replacing parts. :clapping:
BobR
okanogan
ferd
yes, its built into the oil pump. there is also a high volume oil pump available from napa for about the same money.
ford_2.8
center,mo
thanks for the help but it does have the high volocity oil pump in it now and its not gettin oil to the top end or somthin cause i had the valve covers of and they were all loose so i tightened them up and they just went back to ticken. when you first start it cold it will berry out the 100 psi oil gauge at idle at 190 degreese it has no oil pressure at idle so i have no ideas besides the top end or maybe the block is cracked?
