2.9L Headers on 4.0
Jonkuli
4.0 L
I have a 1988 2.9L Ranger STX and I was rebuilding the engine. The exhaust manifold bolts all broke off in the heads. I took the heads off and had the bolts burned out, the valves redone, and the head milled flat to put back on. After i put the engine back together I can't seem to get it running. I decided to upgrade to a new truck. I have the headers for the 2.9L and I was wondering if they will fit on a 1991 4.0L? I just bought them a few months ago so I would hate to not be able to use them if possible.
chilsam
chillicothe il
91 branger
300 six
R U going to sell them if so how much? THANX!!
chilsam
chillicothe il
91 branger
300 six
N i was wondern did u have intake machined 2 compensate for heads setting lower on block? could have a few vacum leaks hope this helps.GOOD LUK!!
gaz
659
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
Jonkuli,
Yes you can use the 2.9l headers on a 4.0l. You may have to deal with the "Y" pipe being different and may also have to block off the EGR opening depending on which headers you purchased.
