2 Wheel Drive to 4 Wheel Drive Conversion 1987 EXT Cab to 1987 Extend Cab Manufactured in Minnesota
creases1
Springfield IL
Ford Ranger STX
Factory Lift for STX
Does anyone know, if you can convert, a 2wd Ranger Extended Cab to a 4wd Ranger Extended Cab with a 4 wd donor of the same year ? In this case it is a 1987 Ford Ranger XLT in excellent condition. The donor is the 1987 Ext Cab I have sitting in the garage literally rusting apart. I was hoping that it would just be swapping components between frames like the front components and a couple of parts off the rear end like the Blocks on the springs, the sway bar etc.
Any feedback would be appreciated, I really feel like I could make an excellent truck if it is worth the effort. Thanks
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
You should just give all of that crap to me and buy a new truck.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
If you have both trucks, wouldn't it be simpler to just fix up the one that's already 4x4?
creases1
Springfield IL
Ford Ranger STX
The 4x4 is the one in the garage that has a serious frame rust issue.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
And yes you can do it. In your case with info given I would do a body swap unless the chassis on the 4x4 is smoked.
If it is...then the k member and front axle needs swapped. Very involved but can be done. How is the 4x4 chassis?
On edit...see the response.
The k member swap is it for you.
alwaysFlOoReD
5,093
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
AFAIK the front crossmember is both riveted and welded to the frame. The 2wd and the 4x4 crossmembers are not the same so need changing along with the axles.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Search it here. I have done it in several ways. Usually drill a hole and use a body saw or sawzall to pop the upright welds from the k to the rail.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Or a Dana 30. Or Dana 44....or 60. Or jk.........
creases1
Springfield IL
Ford Ranger STX
The 4X4 is absolutely bad at the rear forward springcups on both sides but especially on the driver side. You can push a baseball thru the hole on the driver side. It is darn near severed in two. the rust has degraded the gauge o steel on the rear section of this truck.. It is smoked. I have a good amount of $$$ invested and really like these trucks. Now I have a 2WD Ext cab 1987 Ranger that was hoping to combine the best of both and have a decent 4X4 Ranger to drive.
creases1
Springfield IL
Ford Ranger STX
I d
Do I have to pull the body off the frame to get the stuff I need ?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
No. But that said I would remove the front core support on a short cut at the cab horns and pull the engine
I need to make a how to for that.
creases1
Springfield IL
Ford Ranger STX
Thanks Yep I thought I would need to make a cut or 2 :)
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Self evident.
This is not a short cut off, it is a long cut. Short cut leaves side pillars intact.....
But the horns where the hood meets the firewall is the area to cut. It's short with a low amount of spot-weld cutter work. This gets everything out of the way, and makes it easy to remove and replace with a few bolts...and wiring connectors.
Of course it also outlines the easy way to convert your 2wd via leaf spring dana 60 to 4x4....and fit a big block.....but the core/inner fender removal is time well wasted on my eyes.
Swapping in a Dana 28 ttb is not my first choice. Dana 30 would be my first choice in your case.
