2000 f150 4.6 plug removal
Little Red
2000
4.0,4.6
This truck is new to me. I have a miss in #7 cyl. What's involved in pulling a plug if the coil is good. Do I have to remove the fuel rail? Thanks
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
I think your coil is held on with a 10mm socket bolt IIRC. Be careful pulling the coil, sometimes you can rip the boot and you'll have to dig it out. Cylinder 7 is a PITA on mine. Seems like the EGR pipe is right there. Buy good plugs, and use anti-seize on the threads.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
7mm, preferably a swivel.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Thanks Sasquatch, I couldn't remember for sure. One more trick I learned is to use a rubber hose on the end of the plug to start it in the hole. It's like putting the plug in by hand. This helps in the battle against stripped threads.
Sent from a Commodore 64 using a 300 baud modem
Little Red
2000
4.0,4.6
Shane, I got a socket on the bolt and soaked it with Blaster beforehand. It won't come loose. Any suggestions? It's under the fuel pressure reg. I think.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Yeah, it's the third one back on the drivers side. I would recommend letting them soak overnight if it's not coming loose. How long did you soak the plug for? One other thing you could try is let it run for a minute to get it warm. Just remember, this is why you want to use the anti-seize.
Little Red
2000
4.0,4.6
Yeah, I sprayed it twice last eve. and twice today and warmed it up. No-Go. I'll try again tomorrow. Funny thing is I ohmed it out and it reads the same as #8. I suspect the plug. I bought it used from a gypsy car dealer and he said he changed them last spring with the brake pads. Well,the pads were replaced but I question if the plugs were, as tight as this coil bolt is they're probably orig. with 200 k on them. Thanks. any more ideas i'll welcome them.
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
I'm pretty sure mine were original with 205,000 miles on them.
You could just keep driving it. The plugs will remove themselves eventually.
On a more serious note, once you do get the plug out, you can tell if it is original or not because the originals will have a little green or yellow paint dot on the top of them.
Also, if your boot doesn't want to come off, if you have a blow gun and a compressor you can put a little bit of air down through it. It blows it up like a balloon and breaks it away from the plug.
Little Red
2000
4.0,4.6
Happy days. I drenched the coil bolt with Blaster again after I drove it around to warm up. I got the bolt out this AM after I pulled an easy plug out. The bolt came out just like I think it should and the plug was in good shape. The #7 bolt was tight at first. I guess it takes a while for anything to soak into such a tight fit. I pulled the plug and it was in the same shape as the easy one. I used anti-skid on the easy one's plug and coil bolt. I did the same on # 7 after I got a new coil. The old coil ohmed within .1 ohms as the new one.I guess it would break down under load. I put the new coil in and fired it up. It ran better than when I bought it. The mil. went out after 3 starts in 10 mi. I'm ready to rock now. Thanks all.
