Ok, on the body of the switch there is a little "slide" that is retained by two barbs.
Those "Barbs" each have a little tab on them.
{Pressing those two tabs towards each other will allow
you to slip the slide upwards (towards the pedal)
Once it's up 3/8" or so it will literally fall off the clutch multifunction
switch and allow the switch to be pulled sideways off the pushrod.
IF you could SEE it you'd probably have it off already.
AD
