2000 Ranger tan interior
da-chief
9
Gadsden, AL
Ford Ranger Sp
I am trying to match my interior to itself! One door panel has been sun bleached, the other side is darker. I have discovered that Duplicolor Desert tan is too yellow, does anyone know if the SEM brand Ford Lt Parchment is closer? SEM used to make a color called buckskin, and that is what I really want but dont see it listed on the SEM page anymore.
Gozi
27
Garland, TX
Ford Ranger XLT
P235/75R15
Same question on SEM Color Coat. 97 tan interior. 1997 Door code is EX. Going to be using Satin Black with a high gloss clear coat on black interior trim pieces and spot above door armrest. Trying to find black armrest from junkyard. But thought I would paint the faded faded tan full center console picked up from a junkyard. Hit same problem as you. The tan color of the console is same as my interior but just really faded in visible areas. Anyone get close to match the tan with the SEM product? Bob, there is SEM Color Coat Buckskin listing on ebay right now. I'll check around local paint shops to see if I can pick up a SEM Color Chart. Check back in a day or two.
da-chief
9
Gadsden, AL
Ford Ranger Sp
Gozi, I bought a can of SEM 17053 and it IS the color. I sprayed a strip on my door panel, and the next day could not see where I sprayed! Medium Parchment is the color name.
Gozi
27
Garland, TX
Ford Ranger XLT
P235/75R15
Thank you sir.
da-chief
9
Gadsden, AL
Ford Ranger Sp
Here is my interior, there is some of this color SEM 17053 on the shifter console. ACC carpet.
60240
Gozi
27
Garland, TX
Ford Ranger XLT
P235/75R15
Looks great. New ACC Carpet, did you get the ACC floor mats?
Red_Ranger_Rufus
Firefighter
23
Missouri
Ford Ranger 2W
2.5 (4 Cylinder)
NA
NA
Thanks for sharing. I bookmarked since I have the same year/ interior color.
da-chief
9
Gadsden, AL
Ford Ranger Sp
I am probably going to get generic ( Parts Store) floor mats of the correct color, instead of doing Weather Tech. Those things are expensive. Also for hat it's worth, I replaced the plastic sill plates that Ford graciously put on the floor, with aluminum strips painted with self etching primer, then coated with the same SEM 17053.
Gozi
27
Garland, TX
Ford Ranger XLT
P235/75R15
I only ordered one can Medium Parchment paint cause I wasn't fully sure if it would be the same color but it came in today and cap looks real close next to console. Door panels, rear back panels, dash, dash passenger side air bag panel, and front floor side panels don't match the other panels exact color. Going to have to order more paint.
