2001 3.0 Cylinder Head Torque
skyjack
PA
FORD-Fix Our Rust Daily
Can anyone set the facts straight here on the proper cylinder head torque specs for a 2001 3.0 Ranger? One method is the 5 step (37 ft lbs, loosen 1 turn, 22 ft lbs, 90 degrees, 90 degrees).
Method 2:
1. Step 1: 59 ft. lbs. (80 Nm).
2. Step 2: Loosen the bolts one full turn.
3. Step 3: 40 ft. lbs. (55 Nm).
4. Step 4: 63 ft. lbs. (85 Nm).
I have a torque rotation meter, and would put it to good use here if necessary. So which method is recommended by Ford for the 01 Ranger? Thanks!
mattswan267
Boring, OR
3.0 liter
I just rebuilt my 1999 ranger 3.0 and if I remember right the head bolt torque was something like
step 1: 27 ft/lb
step 2: loosen 1 turn
step 3: 73 ft/lb
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
649
Central Indiana
My Haynes manual says to follow method 2 as you posted for all 99 and up 3.0's. Except it gives ranges for steps 3 and 4. For step 3, it says torque to 34-40 ftlbs, and for step 4, it says 63-73 ftlbs. Make sure you follow the proper torque sequence as well.
