2003 3.0 valve stem height
kartracer
lodi
ford ranger
anyone have a manual they could take a look at or know what it is. I guess I could check a few of my own to get some what of an idea. any help would be great. thank you
91stranger
512
Whats round on the sides and hi in the middle-OHIO
Gets Mo Chicks
4.2 straight six powered by gremlins, goblins and mudbloods.
Uhhh… Like a tire valve stem? Kind of an odd question. I personally use the 2" valve stem because they are easier to fill. The smaller ones work too. Can you explain more on what you are needing to know?
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Since he mentioned the engine I'm guessing he means intake/exhaust valves. :dunno:
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
I'm just curious why is this information important, I mean cant you just buy new valves? What are you trying to do? If you look up replacement valves for a 3.0 is it not correct?
kartracer
lodi
ford ranger
im rebuilding my heads, when you grind the seats & dress the valves,the installed height will change,i checked the height when I pulled them apart to get some kind of an idea what they should be,but the I & E valves heights were all over the place. with a non adjustable rocker arm & hyd lifter you still need to some what close. I gave up on rebuilding these heads now since the E seats were so bad I would have to pay a arm & leg for new seats.i just happened to look at this to see if anyone responded,so theres alittle more explaination.
kartracer
lodi
ford ranger
In the ford service manual there has to be a section showing you how to install rocker arms & how to check for clearance in the rocker arm & lifter,in other words if the height is to tall any number of things can happen,...…………….
Dirtman
13,328
41N 75W
It's up there.
It's down there.
Round.
Wish I could help but my manuals start after the 3.0 was discontinued.
@adsm08 might have the info or @RonD .
Now they both just got bugged to join the conversation. Best help I can offer. If they dont know... no one knows. (y)
