2004 XLT front suspension squeak
CapeCodRanger
Cape Cod
My front suspension has been squeaking for the past couple months, mostly on the drivers side. I know there could be alot of things but should replacing the shocks fix it? If so does anyone have any good info on shocks (under 100 each) in a stock ranger.
JohnnyO
Moderator Emeritus
Forum Staff - Retired
2,860
Pittsburgh, PA
2.3 EcoBoost
1.5"
"220, 221, whatever it takes."
Most likely it is the ball joint.
CapeCodRanger
Cape Cod
I just had the ball joints replaced under 10,000 miles ago, and its just going over bumps
JohnnyO
Moderator Emeritus
2,860
Pittsburgh, PA
2.3 EcoBoost
1.5"
Try getting some grease or WD-40 into the swaybar bushings. For shocks I'd get Monroe Sensa Tracs if you don't off-road much and Monroe Reflex if you do.
