2006 F150 5.4 3 valve shuts off
buell-eyed-devil
21
Wesley Chapel,Florida
FORD
5.0-ZF in process
3"body on new poly body mounts
Hey ya'll, watch this
have a 06 F150 that when you drive about 10 minutes starts running erratic, idle drops very low and then shuts off. No codes. Checked all fuses and relays. Need help please
alwaysFlOoReD
5,122
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Cam phasers? My 04 had bad cam phasers. I knew that when I bought it. Couldn't afford to fix it properly so I put in 10w40. Eventually going to 15/40. I got another 30,000 I'm out of it before the motor pooched and sold it for $200 more than I bought it for.
There is a seal that goes bad and then oil bypasses the tensioner. Using thicker oil is a temp fix.
buell-eyed-devil
21
FORD
5.0-ZF in process
Thats funny. It was running perfect before they changed the oil....hmmm
Be very careful with this. The seal mentioned is the gasket that seals the hydraulic tensioner to the block. This seal being bad can allow the engine to skip time, one chain link at a time. After about 60* (yes, it will run that far out of time, the phasers have a range of 50* in either direction) things get broken. Each time a chain link is off one tooth that is 10*.
Try unplugging the VCT solenoids before starting the engine. That locks the phasers in a set position at 0* advance, and if the VCT system is causing the issues they will stop.
I'd also drop the spare tire down and inspect the FPDM bolted to the spare's cross member. They are known to rot out and can cause all sorts of issues as they begin to fail, and don't always set codes. Just find it, unbolt it, and look for a giant hole on the side that was against the frame.
If you find that spend the extra money on the Ford service kit. The failures are caused by stuff getting stuck in between the frame and the module because they sit too close together. The after market kits don't fix this issue, but a Ford service part will come with stand-off bolts that move the module about an inch out from the frame.
