2008 ford ranger pats key and ignition lock clyinder
smitty2855
ny
3inch body lift
I got a 2008 ford ranger XLT 2.3 2WD 5 speed manual I need a new ignition switch lock cylinder and 2 keys that can be programed the security key, pats. anyone got any idea where I can get one that will work and maybe a link to it?
fastpakr
2,840
Roanoke, VA
You can program the keys in yourself using Forscan.
smitty2855
ny
3inch body lift
what is forscan?
smitty2855
ny
3inch body lift
do not have a laptop just want to know where to buy a ignition lock cylinder with 2 progamable keys for my truck. thanks for info though.
Almost anywhere. But you will have to get the keys programmed somewhere. The customer programming option only works if you have two working keys in your hand already.
smitty2855
ny
3inch body lift
tried to have keys programmed at a ford garage they said they couldn't program them so had to buy keys from them which I did but I suspect that they just wanted to sell me keys. The ignition switch did work that I had bought. anyways all fixed for a while now thanks.
