2011 "leveling kit"
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
So, I picked up a set of the rough country leveling keys formy 2011. they're for the 2008 and back trucks. Figured it would give me the older trucks ride height, plus a claimed additional 2-3 inches.
So here in lies the real question...
For the rear, is it going to be better to use the pre 2008 blocks and shackle, blocks and an add a leaf, or explorer spring packs?
Open to suggestions on this one. No.idea which will be better in the long run, and handle better.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,637
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
So... are you planning on using all of what the rough country keys can give you? Do you have a tire size in mind that will go on?
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
Yesum, planning on utilizing them to their "max"
Not sure on tire size yet. Probably going tonswap my 88s 31s on it for the remainder of the winter.
Uncle Gump
Token Old Guy
13,637
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
"Max" can put things on pretty steep angles. Wear your stuff out "quick" and where the hell did my road manners go angles.
I've never done what you want to do... so no advice for what to do in the rear either... But I'm watching you proceed with the plan so you can teach me.
To quote Shark Tank... "For those reasons... I'm out"
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
I suppose my goal would be 4" higher than factory 2011.
A man can do a lot with 4 inches. Trust me. I know. ??
Uncle Gump
Token Old Guy
13,637
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I would have no idea what that is like...
My 06 at stock ride height clears a 32 inch tire. I would think your RC reindexed keys will put your truck higher then mine at the lowest possible point. You will probably have to get those in place and then see what you need to make up in the rear.
1996xlt
23
NC
I had an 02' with the torsion bar twist and belltech shackles set to the highest mount on stock (220k springs) and think I could've easily fit 32"s under it. The ride wasn't terrible, but before I got rid of it I had a set of explorer leafs to swap out and never did it because I thought the ride may be too stiff unloaded. Only pic I had of it before I sold it (feel free to ignore the dusty mustang.)
36945
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
I'd suggest the pre-'08 blocks and extended shackle. Explorer leafs would be good option too. The add-a-leaf is likely to stiffen the ride too much (and short AALs also stress the rest of the leaves too much IMO).
sgtsandman
Aircraft Fuel Tank Diver
12,927
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Are you thinking of upgrading the rear leafs from 1250# to 1750#? If so, lift pre-2008 blocks might be the better approach. If you are looking at keeping the stock springs, longer rear shackles might be the cheaper/better approach.
09fx4guy
176
USA
Pre Key w/ #1 Bars
265/70R16
I did both on the rear. I found a set of 2.5 inch blocks from an earlier ranger to replace the 1.5 inch blocks on mine. Then I added the belltech shackle, but didn't use the end hole, I used the one before it. This got me about 1.5-1.75 inches of lift.
For the front, I would recommend that you see what torsion bars you have, and maybe replace them with some #1 bars.
I originally had purchased the earlier torsion keys (pre-key mod) for the front of mine, and had to max out the driver side key to level it out ( I was running factory B rated torsion bars) with about 40,000 miles. When I upgraded to #1 bars (purchase from Tasca for about 200 bucks for both), I was able to level the truck and had quite a bit of thread left on the adjustment bolt on the driver side (1/4-3/8 inch). The ride improved dramatically.
Also, upgrade the shocks while you are there, you will need extended length (I used Rancho 5000X).
I currently run 31 inch (265/70R16) tires, and could easily clear 32's, maybe even 33's
No complaints, and I don't think I will need to upgrade the driveshaft anytime soon.
HOWEVER, if you plan on keeping the truck for a long time, and you want 4" of lift, just get the Superlift Kit and be done with it.
PetroleumJunkie412
6,565
Dirtman's Basement
2.9l Trinity
So uh... Gump... Are you saying mine's bigger? ?
Yes, I'm still 14 at heart. Judge all ya want; I'm happy. :thefinger:
So the idea behind the exploder springs was 2-3" of lift without blocking and shackle-ing my way there while keeping a softer spring. I'm starting to suspect my spring packs have been overloaded a few times; put a BII rear sway bar under it the other day (it did not have a rear bar from the factory) and its a different truck now. Guessing theyre still wrapping (feels like it at least). My overloads are facing the wrong direction (they bend down instead of up), which is what leads me to suspect they're shot. I texted a photo to bobby asking if they looked right to him. His answer was "hell no"
I'm forever leery on using lift shackles from my Jeep days after watching the TJ guys have to prybar theirs back to the right position after getting in a bind. Are they a problem on ranger? Any (even ancidotal) stories of shackles flipping over?
Pulled a set of lift blocks, sway bar stuff, U bolts, spring plates, etc. out of a 2003. Have everything blasted and powder coated on the shelf ready to go. Just haven't installed until I have a game plan.
Re-using U bolts... Have heard storied both ways. Thoughts?
Not a fan of the AALs either. One of my XJs had Superlift AALs on it. Forever squeaky. Would like to avoid, but if a better option than blocks and shackles, so be it.
I have thought about a few times. Not sure what I have under there now. 3+1 configuration with Berlin eyes if its any indication.
I like the 1750s under the 88... to a point. They are really nice to have when I use the bed. But, it rides like a damn buckboard at times.
I do want to keep the '11 as more of a street truck, so handling is the first consideration when it comes to the suspension. Especially since the remainder of the M90 blower kit shipped this morning :yahoo: Just need to find a machine shop not run by satan to finish off the plenum, and it will be installed.
Yes, I do realize lifting raises CoG, etc, etc. However, I'm also 6'3", and its a little low for me just getting in and out.
Thought about the superlift kit, but, I'm cheap.
Literally just looked at the #1 bars on Tasca this morning, and read a few threads debating the differences in part numbers for them. I still am unsure of which they are, mostly because I need to crawl back under it and look.
Amazes me that no one seems to produce an improved/aftermarket bar for these trucks. Figured someone absolutely would have. Very interested if you know of one. How do you like your #1s? Just a ride quality improvement, or noticable differences in handling, etc?
The current ones I believe are the B rated bar with 118k on them. No idea what their service life is. Definately feels spongy on the front, and tires are wearing slightly more on the inside. Waiting until I have the suspension modifications finished for an alignment. These tires are garbage (Cooper all-seasons), so no loss if they die an early death.
Coilovers were considered for the front until I saw the price tag for the kit. Not happening.
Already hung Bilstein 4600s on all four corners. Checked length on them when I did, and I can safely go up another 4" or so before needing longer shocks. Crazy how low the 2011s sit.
Not sure what I'm going to land with for tires. Something in the 29-31" range. Unsure if I'm sticking with the 15" wheels, or going to 16" yet. Since pavement and dirt roads are going to be the majority of the truck's service life, I've been reading on what to go for as far as tires are concerned. I'm leaning towards something in the 30" range, just much wider than the 235/75/R15s that are on it now.
Aftermarket rims and (unfortunately) spacers have been considered to increase stance width, but, once again, I'm cheap. Would like to stay with aluminum construction for brake cooling though.
sgtsandman
12,927
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
3/1 springs are 1250#. Yeah, your over load plates should be flat. At least mine are.
If you pre-2008 key the truck and put blocks in the back or install and extended shackle, 31” will fit just fine. Stock suspension, the 2011 is a bit over stuffed and rubs on the wheel liner humps at full lock and probably will after a heavy dip.
That is part of the reason I’m focusing on the suspension upgrades over the regear and locker first. I’m still price shopping but to get everything at pre-2008 ride height and proper shocks for the height increase, it’s looking like it’s gonna cost a grand to do it right.
EDIT: The thought occurred to me that people are going to ask why so much. On top of keys, lift blocks, shocks, and u-bolts, there is #1 torsion bars and 1750# leaf springs. Plus the necessary tool for the replacement of the torsion keys.
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
8,854
Nocona, Texas
4.0 / 2.3 Ecoboost
6-inches
33x12.50x15
On a side note, let us know how it rides before and after.
The Bilsteins you're using now will accept the 4-inches of lift? Will they accept the additional down travel? Which shock P/N's are you using?
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
A TJ does not have shackles (but a YJ does :p ).
Never seen an inverted shackle happen on a RBV (well, once on a poorly-done SAS I did see one lol). Plenty of people here run them too (inc. myself).
This thread came up some years back...
Uncle Gump
Token Old Guy
13,637
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
That's the problem with cranking the bars up 4 inches... there is no down travel left.
