2WD Manual transmission options
tinman_72
139
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
Hi guys,
I am currently collecting parts for my '93 2wd V8 swap. Having trouble figuring out which way to go for the transmission. I currently have a T5 out of a '90 Mustang GT but I am thinking I may want to sell it and find a M5R2, since I will be pushing around 400 ft/lbs at the flywheel. As I see it these are the pros and cons of each transmission:
  • Use the T-5.
    • Pros
      • I already have one.
      • Shifts smoother than M5R2
    • Cons
      • T5 uses mechanically activated clutch. This means spending $300-$400 on a hydraulic throw-out bearing. If it was a one-time thing I wouldn't mind so much but as we all know, throw-out bearings wear out on a regular basis.
      • shifter is in the wrong place.
      • Not sure if speedo cable is plug and play
      • Weaker transmission than T5.
  • Sell T5 and acquire M5R2 from 1997? to 2004 F150 with 4.2L
    • Pros:
      • Stronger transmission than T5
      • Can use the Ranger hydraulics
      • Shifter is in the correct place.
      • Local salvage yard has tested units for $400
    • Cons
      • Shifts like a truck transmission
      • I thought these transmissions do not have speedo gears. Looking at pictures on eBay (linky linky), I am wondering if some years did, in fact, have a place for a speedo gear. Would my cable work in this case?
  • Sell T5 and use M5R2 from early 90's (unsure of exact years) F150 with 5.0. (Not sure if 5.8 used M5R2 as well).
    • Pros:
      • Pretty sure my speedo cable will work with this transmission.
      • Ranger hydraulics will work with this transmission.
    • Cons:
      • This will place the shifter under the dash
      • Salvage yards that are relatively local want $900
Any pros/cons that I have missed? Any other insights?
19Walt93
4,498
Canaan,NH
351
3"
235/55R16
F150's through 96 with a 302 could have a 5 speed, 351's were all automatics. I personally detest the Mazda sourced transmission, I never liked the way they feel when shifting. The T5 in my Mustang survived 20+ years of drag racing(13.8@102 and over 80,000 street miles and still shifts fine. I'd use either a T5 or Tremec with either an external slave cylinder or cable actuation. The ones that mount on the bearing retainer work slick until the clutch wears a little and they need to be readjusted because the adjustment is done with the trans removed. In NH we almost never see a 2wd F150, we certainly never ordered them for stock so I don't know how many 2wd transmissions are out there. I'd also question the condition of a transmission that can't be less than 26 years old. My 351 Ranger runs a C4 because I had one, if I'd had a T5 I'd have used it.
tinman_72
139
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
2wd trucks are not rare at all in Georgia. They are just too old to find nowadays.
The main reason I am leaning towards M5R2 is that it will be pretty much plug-n-play. Unless I am looking in the wrong places, all the conversion kits seem to cost around $250 for the slave and another $250 for the master. Not looking to spend $500 or more on wearable parts.
I did find where a guy used a cheapo Toyota slave cylinder on his T5 and detailed how he mounted it. This would not be beyond my capability but I don't know how I would determine if my master cylinder is too much or too little for that slave.
Blmpkn
Toilet enthusiast
6,381
Southern maine
Ford Bronco
2.3 EcoBoost
2.3
2.5"
If your TOB's go "on a regular basis" you should either stop installing used ones or quit resting your foot on the clutch when your driving.
tinman_72
139
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
My throw-out bearings don't wear prematurely, but they ARE a wearable item.
Does anyone know if '93 Ranger speedo cable will work in the 99-04 M5R2?
72961
No members online now.
