3.0 no power...
DFracing
i have a 2000 3.0 ranger manual transmission and i have NO power, my friend with the same truck but a lift and automatic tranny can pull out in front of me in a race, and i happen to have a k&n intake flowmaster 40 series throttle body spacer and smaller tires! while he has none of that and larger tires. I dont understand why this is happening, even my friend that has 4banger 2.7 4runner has more power and torque. i just dont understand why i have no power whatsoever. i know its a 3.0 but dang... anyone got any ideas of why i have an engine with NO balls, when ive done everything to give it more.
betomonroy
San Antonio, TX
Different differential gears.
Try going 4.56:1 and 225/70 R15 or 235/70R15
Gotta_gofast
33
Wisconsin
6.0L Powerstroke
Well, a muffler and a TB spacer won't net you anything. The K&N unit might be giving you a 1-2 hp increase...
Its quite possible his truck has a numerically higher gear ratio in the rear axle.
Southern3.0
New Port Nowhere FL
'96
2.3, what a turd...
Maybe a full tune up is in order?
And what RPM are you shifting at?
DFracing
i shift at 5g and double clutch but tats where he pulls away, on his truck he can also do about 10 mph faster in first gear, and so on.
Toms01PSD
37
Sanford, NC
7.3
While intake and exhaust help your engine breath and flow, they don't necessarily turn it into a drag truck. Try changing your gears. And when's the last time you replaced your filters? I replaced my fuel filter the other day and I noticed it ran a little smoother.
Gotta_gofast
33
Wisconsin
6.0L Powerstroke
There's no need to double clutch your trans... thats why it has syncros.
DFracing
yea if i shift too fast through 2nd it grinds so thats the only reason, i realize its not a drag truck and thats not what i want but, id like to have a decent amount of power on tap when i need it and it really doesnt have much, as far as i know the fuel filter has never been replaced. i will check it out though
Clay_95Ranger
Las Vegas, NV
Straight tune up, oil, plugs, fuel filters that works for a tune up and if that doesnt work, except that your truck is not a dragger...
Toms01PSD
37
Sanford, NC
7.3
I definately would. It's below the driver's door on the inside of the frame rail. It's like a 10 dollar part at autozone. Don't forget to release the fuel pressure at the schrader valve either! I have a 3.0 in my 99. It's got some torque but it's still a dog.
fleck
Florida
Mazda
I have the same problem with grinding shifting into 2nd fast and I was told it is due to not having bushings in the shifter (for some people its bad bushings, but my mechanic said I have literally NO bushings). Supposedly a bushing kit will fix that but I'm actually saving up for a Hurst shifter.
Gotta_gofast
33
Wisconsin
6.0L Powerstroke
Well, our transmissions weren't meant for speedy fast supercar shifts anywho. lol but a firm shift shouldn't take very long to complete. If I jam the shifter back I will hear a quick grinding sound but a steady but quick shift will get me where I'm going. Fleck, in your sig it says you removed your thermostat?
fleck
Florida
Mazda
Yeah, you're either the 2nd to ask or that is your 2nd time asking. What is your concern with no t-stat?
Gotta_gofast
33
Wisconsin
6.0L Powerstroke
Your engine isn't able to operate at minimum of 180 degrees. Your computer will always run rich (thinking it needs to be warmed up). Also, your increasing the wear in your engine because the tolerances set by Ford are for operating temps. When your cast pistons expand at a different rate than your iron block.... well you get the point.
fleck
Florida
Mazda
Alright, my mechanic isn't too keen on some technical aspects especially on newer stuff he isn't experienced with. We're going to do a radiator flush within the next few days because I still have some sludge to clear out of there, so I'll address the issue then. Thanks.
