PayDave
- Sep 30, 2008
- 0
- Ford
Does anyone know what my problem is?
I've got a 94 3.0L that runs smooth, BUT......
...It's got milkshake in the rad, along with little black bits(Carbon???).
...I do an oil change every couple months because the oil gets washed down with something, (Coolant?) drasticly raising the oil level, and robbing power.
...The truck sometimes smokes a lot from the tail pipe (steam?) when started, but cleans up after a couple miles.
I think it could be a craked head or blown gasket. If so, What could I pull some heads off for a rebuild? Would Tarus heads work? Anything else?
A compression test should help me locate a bad head, eh?
If anyone could help me out with some info on this issue, I would really appreciate it.
Thanks.
Thanks.
