302 rad/cooling pics/ideas
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
when i wake up tomorrow....i will have to finish a project for my nephew. i will try to take a pic of my truck and it will be easier to understand my stupid...
its still dark when i get in from work and i am out of beer....so it will have to wait till i wake up:thefinger:
85_Ranger4x4
17,848
SW Iowa
No big hurry, I am probably not going to try to crack the A/C nut until next spring.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i took pics with phone....not working to puter.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
did not forget.
whwaufmaio
U.S. Military - Active
Stafford, VA
3 inch body
Get to it
hey guys, i went with a 4.0l radiator from my local yard, cut and dropped the radiator support down and welded it back in. fit like a glove and got it all hooked up, damn thing leaks... good thing is the yard has at least 10 more to choose from. however i found this online this morning, anyone with experience or thoughts? 3 row all aluminum, i'm tempted to just get it and see what happens.
http://www.radiatorexpress.com/product/radiator/ford/1986/ranger/super/29l-v6/221483/1137518#
Bird76Mojo
1,265
IL
If you don't want to tuck the radiator into the core support further forward than the stock location, then yes, that model looks like it should work fine.
GB :)
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
Hey all, I know this is an older thread, but instead of making new one, just carry on here.
I have the Northern 205138 rad for my swap. I am having troubles finding a proper fitting rad cap for this. as this rad seems to be a touch thicker in the screw down part. what have you had luck with and how many pounds are you running? I am thinking 13-15 should be fine.
cheers thanks
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i use the quick bleeds in 16.
insaneranger
42
Tennessee
302
225/40 R18
cheers thanks
I have the exact same radiator. A standard radiator cap from any parts store will work. It's just a tight fit. Northern suggests a 20-22 lb cap, but I'm using a 16 lb cap on mine.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Angie
368
92 & 83 project
4.0L 302
thanks insane.... yes it is a tight fit, here i was thinking it was just me not pushing hard enough.... cheers !!
Ramcharger90
1,708
N/A na
306, Bcam,
I used a rad for a 4.0 for my year truck and an 3000cfm puller electric fan wired in with an after market controller. The radiator is tiny in my opinion so I used a 180° thermostat so it opens sooner it stays cool and runs great, obviously if you are gonna be flat to the floor alot you want a different radiator.
35Remmy
12
Binghamton NY
1999
2.9, 4.0
Use a Northern brand Ranger V8 swap radiator. In the middle of my 363 stroker swap, leaves a lot of room. No hacking up the hell out of your core support.
Junglejoe
66
Columbia Missouri
6.0
Why dont you guys just use the stock v8 explorer radiator? It fits perfect even with the clutch fan and shroud
Junk Collector
Truck of Month
4,802
Rapid City SD
I have a Duff V8 swap radiator... looking through this thread it appears VERY similar to that Northern brand one. I don't think Duff made them and I seem to recall that it came in a box from another company, either Ron Davis or Big End, I can't remember which. Works well enough I guess although it's started leaking.
Pics or it didn't happen :p
