350 swap 1988 2wd
Gmcgill
Oregon
I have a 88 2wd ranger with a service bed on the back, it used to be a city work truck but was retired along time ago. I picked it up with a blown motor and trans the rest of the truck is clean, and being my first rig, has allot of memories attached. I was just donated a 350 just needs a tune up. I was just wondering any tips and tricks, any converson kits I should get or any info at all would be awesome! (I know it's a chevy but free.99 is a good price plus there cheap and easy to work on, also the trans will be able to push the 2,000 lb. Utility box allot longer then the 2.9 tranny did.)
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
Here’s the shirt and skinny.
Engine mounts. Get a set for a early 60s impala. Then take a piece of Chanel. Weld it to a piece of 1/4 plate. Set the motor where you want it. Weld the plate to the crossmember.
Make your own trans crossmember.
Get the correct yoke for the driveshaft.
Radiator you have 2 choices. Jegs brand 28x16.5. Or one from a 90s Dodge Ram van 1500. Both will require core support modifications.
Also. Lose the in take fuel pump. Too much pressure for a carb. Either run the mechanical one on the block. Or get an in-line electric pump.
Oh. You’ll also need a small cap hei
Exhaust. I run the 2.5 ram horn manifolds. And I cut and boxed my crossmember to fit them. If you’re not after all the power. Look for the 2” ram horns that angle back. They fit a lot better
Steering shaft. You need a 36 spline end at the box. You can order a universal joint from speedway motors. And weld it onto your existing shaft. And eliminate the rag joint by the box. This will give you the room you need for the exhaust.
That should be enough to get you started.
Gmcgill
Oregon
Awesome thank you so much for alall the input it doesn't sound like it should be that bad then, would you say it's worth doing? All the money saved verses a ford power plant?
RangerFabWorks
715
302
I can’t really say. Because I’ve done it both ways. The sbf really is the better swap. So much easier.
But! I do love the sbc in my 88.
Run whatcha got. A v8 ranger is a hell of a lot of fun either way.
