Sorry these pics are so big, i couldn't get the thumbnail link like the last ones for some reason. I still have to post the final installed pic. There were a few differences between this seat and the first one i test fitted, both are the center 2 seater seats from dodge caravans, the first was from a 95 caravan ( w/o built in carseats ), the 2nd was from a 93 dodge grand caravan...to the best of my knowledge the grand caravans are the only ones that came with built in car seats.
The main difference I ran into was the positioning of the kids, the kids sit about 4inches back into the seat ( just an approximation ). So they're more or less in the same spot as the same area as the stock seating. Also I measured a chevy 2500 for heights, etc. In a rear impact with this vehicle, it would have to push the rear end of the explorer right into the rear tires before it would most likely cause fatal injuries. I'd see most possibly a broken leg? But even for that they'd have to go through the bumper, the rear receiver and possibly the axle and tires.
Cost for this....I'm not 100% sure, It cost me nothing. I had the seat from one of the many vans i have, the 5th wheel mounting plates my father inlaw had sitting around, bolts, to the seat i reused the existing ones, going through the floor in the angle,etc again my father inlaw had ( hes a mechanic so he has no shortage of bolts ). Time wise, I think this took maybe 3 hours. But that was putting it in, pulling it out.
I think the 5th wheel mounting plates are WAY overkill, but we workedwith what we had. My original plan was to drill holes through the floor pan, and mount with angle using the stock mounting positions on the new seat, HOWEVER we soon discovered that where the holes line up, there is a box beam under there so it wouldn't work, hence the 5th wheel plates. I would assume any 1/4" platting,etc would be fine. Oh I forgot to mention, the middle seat from the caravan fits perfectly, about 1/2" play on each side.
I'm open to any thaughts or suggestions on this, especially how to make this safer in an accident scenerio. I was thinking of possibly reinforcing the sides underneath the side panels? Any thaughts on this? I'm not thinking of a complete cage, just possibly using 1 x 2" u channel along the sides to reinforce in case of a rear impact?
I'll post the finished pics tomorrow.
