HomeandRanch
- Jun 25, 2008
- 0
- Age
- 48
I have a bronco 2 2.9 l V6 and here are my specs
2wd
Manual trans
1988 Bronco 2
The Truck has a 1997 Ford Explorer 4.0 L flywheel, clutch and starter on it.
My problem is when I start the Bronco my starter stays engaged for about 2 seconds after the engine comes up to speed.
I put a "brand new" starter on it and the same thing happens. Before the swap it did not do this so I doubt the ignition all of sudden went bad.
Has anyone else had this problem? I am going to try to shim the starter out in the next day or two. Does this have any chance of working?
Thank you!
2wd
Manual trans
1988 Bronco 2
Thank you!
