Timbit
- Aug 30, 2007
- 0
- Ford
truck specs:
92 4.0 4x4 XLT,5 spd....HAD air tilt cruise before a cab swap....electronic 4x4 too although shouldn't make a difference as it has own computer to control....
the engine had 170k miles on it..and the cab was rotten...beyond repair!! So I find a 90 2 wheel x-cab truck and swap the cab....don't want air cause it doesn't work, and same with cruise....so bonus the old truck doesn't have it...I use the heater box on the firewall and the heater controls and take out the CC harness...while doing all this swap, I find the computer has been getting wet, and it rotting it out...I was surprised the truck was even running
so I bolt new cab in with NO a/c controls, and CC harness missing, but wiht the computer I decide I need a new one! so I get a computer from a truck out of town, of course, because NO yard in town had a computer for my truck. so I get one that was made for:
4.0, 4x4, NO air, 5spd...everything should be the same....truck runs great after with all this swap done, and we are ok...well truck breaks tranny, and sits for a year, new house, new garage, get everything going, and I get the truck fixed...and replace lots of stuff to make it new again, and also another engine from a 92 exploder...it has 132k miles on it, still runs great.....brings me to my new problem!!!
I have a high idle that won't go away!!..I have replaced all sensors on engine within two years, Except VRS and idle bypass...mind you, I have 4 other IAB sensors for this engine, and all 4 either make it worse or it stays the same...if I let the engine sit for a long time idling it will do fine..right about 800-850 but will go up and stay about a 1k on my tach and be up while driving around even at idle at a stoplight...also the engine seems to really jump around while driving, when letting off the gas it will start to slow the truck down, but will do it with quite harshness....timing chain maybe???
I have HORRIBLE gas mileage, and I still don't know what would be causing this anyone have any ideas here for me? Like I said, all new sensors except the 2 mentioned and also new plugs, wires, filter, all within the past two years...so, does this computer possible cause a problem? cause it wasn't the original specs? and should I break down and get the new IAB valve?
I am just throwing out all issues I see, and also all specs of truck current and all mods that has been done.....I am getting lost here, and just looking for mostly 2nd opinion answers and brainstorming......
Tim
Tim
