91 blue ranger
- Feb 25, 2019
- 12
- ford
- Engine Size
- 4.0
I just took out all the manifold bolts and pulled the hole manifold away from the filter bolt. It is still a little moist in that area but it might be coming from something higher up. Because something is leaking up there. I think it is coming from the intake gaskets. Hope this helps.
Im a little late to this post, but did the fix work? No leaks yet? ANd when you say you dropped the passenger side exhaust only, did you drop the y pipe and then take the passenger side manifold off?
