Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
The clutch spline and disc size is the same between the SOHC and OHV. The flywheel on the early OHV is 6 bolt, The SOHC (and later OHV) uses an 8 bolt flywheel. The same disc and pressure plate can be used on either flywheel.well, I kinda found that info soon after I asked. If 7 out of 8 bolts line up I would be very happy, but will the clutch and all that still work together?
