4.0?
marana az
2.8 v6
i have seen many builds where guys will swap out 2.9 for a 4.0 but my question is how hard would it be to swap out a 2.8 for a 4.0 being that the 2.8 is carbed and the 4.0 is injected or did they make a carbed 4.0 and will my motor mounts work:icon_confused:
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
Same. You still have to swap in the wiring and ecu. All 4.0s are EFI, and motor mounts are the same.
marana az
2.8 v6
how hard is the wiring swap and what do you have to do with the wiring
shawn.m
18 miles se of placerville,ca
just pull everything out of a donor vechile - wiring harness, computer, dash, interior wiring harness, motor, tranny.
take you about 2 weeks
4.0B2
151
Walls, MS
4.0 v6
You'll love the 4.0 in it. It's like it was made to be there.. I love that 4.0 in mine over the 2.9 and it's probably more of a diff from the 2.8 to 4.0. Well worth it.
marana az
2.8 v6
i plan on getting a whole donor vehicle (even though it will piss the wife off but oh well)so i am planning on using the whole drivetrain so what yall are sayin is toss out all the stock wiring along with the 2.8 and swap in the computer and all that good stuff right if so what would be a good donor vehicle
marana az
2.8 v6
and the dash will be all custom im thinkin flat black diamond plate with aftermarket guages
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
The big thing when swapping from a 2.8 is that you need the EFI fuel system as well...
3,614
You will need to find pumps, lines, and a tank from an EFI vehicle. If you can get them from a 90 B2 then you should only need the in-tank pump.
04sd
'90 / '84
4.0 / 4.0
.... if so what would be a good donor vehicle
Your best bet is to find a 1st gen Explorer. From the Ex you can use...
front & rear axles
front & rear springs
engine & trans & transfer case
dash and all wiring, computer
steering column
radiator
Best bet is to get a '90 BII gas tank with the high pressure fuel pump.
Most Explorers will be automatics with electric transfer cases. If you want a 5 speed they can be found but manual transfer cases are hard to come by in Explorers. I've had five 1st gen Ex's in the last few years for parts and only one was a manual transfer case, and the only reason I bought it.
The fire wall will require some mod's for the Ex steering column. Some mod's are also required for the Ex dash install.
Your other option is a 2nd gen Ranger with a 4.0. Pretty much the same deal as the 1st gen Ex.
marana az
2.8 v6
what are the differences between my borg warner 13-50 t case and one out of an explorer i really want to keep it all manual( manual hubs,manual trans,manual t case ) less headaches and less to go wrong in my opinion
marana az
2.8 v6
gears are another thing i really dont understand maybe you can shed some light on this subject im planning on runnin some 33x10.5x15 with some on road use
04sd
'90 / '84
4.0 / 4.0
The Ex has a stronger 1354 but your 1350 will bolt onto an Ex trans without issue. For 33" tires I'd look for an Ex with 3.73 gears, the axle codes can be found in the tech section. The Ex will have a front d35 and rear 8.8, both are upgrades over stock BII. Your current 5 speed won't last behind a 4.0 from what I've heard ( I run automatics).
3,614
For 33's I'd run 4.10 gears.
04sd is right though. Your 5-speed won't last too long behind a 4.0. The 4.0 is a driveline killer. M5OD is about the only way to go with those engines.
marana az
2.8 v6
what kinds of driveline problems/mods should i expect
