4 inch rough country
guitarsgethegals
Lafayette, LA
V6, 3.0L
i noticed that the rough country does not make there lift for 2004 trucks could you still bolt this kit on or would it not work? if not i was thinking of doing the lift part by part what would the process be for this?
nb11
10
South Georgia
2.3l
After '97 2wd front suspensions changed. So it won't work with your truck. Sorry man, I was disappointed that they don't make them for our trucks.
guitarsgethegals
Lafayette, LA
V6, 3.0L
what did they change after 97?
Bennybooster
EMT / Paramedic
37
Medford, Oregon.
The entire suspension system changed in 1998, not even close
The 5in lift you posted wouldn't be bad, but I definatley would jump it
guitarsgethegals
Lafayette, LA
V6, 3.0L
jump??
but i plan on putting 32x11.5 tires w/
1 inch back spacers/adapters
doyouquaxu
26
Orange County CA
As in, you go fast and hit a jump, and the tires leave the ground. Then you hit the ground and your new spindles shear off
read what you wrote. only bolded what doesn't make sense.
guitarsgethegals
Lafayette, LA
V6, 3.0L
what do you have on your truck booster?
RavoHimself
8
enfield, ct
he meant wouldn't jump it. spindles with that much lift for that cheap don't really sound to sturdy under stress. they will probably snap the first jump you hit
do 3" spindles and fiberglass fenders. it will give you plenty of room for wheel travel. and don't do the spacers. they are just an extra set of lugs to worry about. just get less backspacing.
guitarsgethegals
Lafayette, LA
V6, 3.0L
yeah im just going for the tall look i mean 2wd really?
but yeah i have 32x 11.5 mastercrafts and i just want the cheapest way to put them on.....
No members online now.
