4WD not working
Well-known member
328
There is only 2 parts to the system, the 4x4 CM, you just changed, and the shift motor
And the 4WD light will flash if 4x4CM sends the shift motor voltage(relay clicks) and shift motor doesn't move.
The switch is just 3 resistors and the 4WD Lights should flash if 4x4CM doesn't get back any voltage from switch when key is turned on
4x4CM sends 5volts to switch with key on, these are the voltage readings the 4x4CM will get back from switch
3.86v for 2wd
2.94v for high
1.76v for low
If 4x4CM gets no voltage then it would flash 4WD lights
This is not a complicated system, compared to some, lol
I think your "new" 4x4CM is bad, especially if its not "clicking"
Not unheard of
Whats the part number on it?
I am showing last part number for Ranger 4x4CM was 8L5Z-7E453-A, so a 2008 number, previous was 7L5Z-7E453-A so 2007 number
Rock Auto 5% Discount Code: 248EE46702D889 Expires: October 1, 2019
ochoam
New member
USA
Part number is 8L5Z-7E453-A
I would be very surprised if this part was back I got it from a good ford dealer
I am going to call where I got the part from, but I'm worried there's no way to test if the part is bad.
ochoam
New member
USA
Talked with a mechanic I trust about this (not saying I don't trust this form, but he has been great to me in the past)
When he did other work on the car he thought the part could of been bad too.
To prove the part is defective from where I bought it they'd charge me for labor, and I want avoid that.
Do you have to initialize this part?
Well-known member
328
No, the part is plug and play.
You did say you checked the 3 fuses after putting the new part in, right
ochoam
New member
USA
Correct I did
ochoam
New member
USA
Good news, I got it fixed.
I did need to unplug the battery for 10 minutes to 'initialize' the module.
Ranger850
Well-known member
383
Tallahassee Florida
Stock 2"
Stock
Well-known member
328
Good work
Never heard of that but good to know
