4x4 Front Hub O-Ring
Tagg
4
Muse, Pa.
1995
Mazda
Finally found the replacement O-Ring at NAPA that the Ford dealership wanted $ 12.50 for, however it did include a 4x4 sticker (yippee):headbang:
The Ford part # F3TZ-1K106-A is replaced by a 3.50" I.D. x 3/32" thickness, Napa part # 727-2153. Hope this info helps somebody if needed.:icon_cheers:
This is the o-ring between the backside of the hub and the rotor.
AllanD
TRS Technical Staff
134
East-Central Pennsylvania
1987... sorta
'93 4.0
So, how much did NAPA want?
AD
Tagg
4
Muse, Pa.
1995
Mazda
Whoopps !!!
Sorry I forgot to add that !!! They were $ 1.59 each. :yahoo:
Wicked_Sludge
43
Westport, WA
3-point-GO
i got 3 sets from the wrecking yard for free :D
BlackBII
Ranger Custom
Truck of Month
982
UT
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
4x4 sticker?
You talking about the big oring behind the hub body on the pre-98 hubs?
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Yes, they come with a replacement 4x4 sticker for the locking hub knob as well.
Wicked_Sludge
43
Westport, WA
3-point-GO
You Thief!
What did you do, stash them in your pockets?
not at all. i walked into the office with a set of d-35 axle C-clips and thrust washers and a fistfull of hub o-rings, showed them to george and he rolled his eyes and waved me away :icon_thumby:
me and george go back...
ronclark
25
Woodland, WA
95 4.0 with 93 ECU
I got mine at a local 4x4 shop for a few bucks each, since napa said thy could not get them and just use RTV for a replacement :annoyed:
Natedog
5
CA
Good info, I'll see if they still have them.
oldford4x4
Chicagoland
2.9
How are those NAPA o-rings holding up? I tried this same thing a few years ago with a Carquest o-ring and within 2 years it was trashed. I'm not sure but I suspect it had to do with the material the o-ring was made from. I finally just got a service kit from WARN #39128 (I have a '86 with D28 axle but I think it also had the parts for a D35). Though I think it ended up being nearly $20 at the local speed shop, but it covered both hubs.
racsan
4,443
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
i got a new set of mile marker hubs that had thicker o-rings, they were on for about a month and i took them off to drill them with the new rotors and both o-rings had broke, so ive peeled the old o-rings off the other set of hubs and am going to try that. would high-temp rtv (the red stuff) do any good? im thinking no, what with the temps that brakes get to. heres a pic of the new rotor and hub after drilling/tapping. no more of those circle clips! (3) 1/4-20 ss screws. going to anti-seize them as well.
TastySloth
Kittitas, WA
I have been trying to find those little clips, but nobody around here can get them... Anyone know of a place I can order them from?
Black_Splash
Huntingburg, IN
If you have Warn hubs, just talk to Warn customer support. They sent me some for free.
