4X4 low light flashes
RangerJ
North Georgia
1994 Ranger XLT 4x4 manual,4.0. I replaced the 4x4 control module from a salvage yard and it worked well several times but this morning when I started the truck the 4x4 low light was on the dash switch but the 4x4 was not engaged so after pressing the switch a few times the light went off. I then tried to engage 4 low and the light just flashes ,but I have 4 high.
Is this a sign of a bad control module ,dash switch, or some other issue?
Any advice,tips are welcome.Thanks
8,372
Good 4WD troubleshooting guide here: http://www.therangerstation.com/tech_library/transfercasetroubleshooting.htm
1994 and older or 1995 and newer
Flashing light only for 4lo would mean the shift motor didn't rotate enough to engage 4lo, or didn't rotate at all because the module didn't get Neutral signal(clutch pedal in, or automatic in Neutral), or Brake light signal(foot on the brake pedal)
4lo requires these parameters to engage, 4hi doesn't("shift on the fly")
RangerJ
North Georgia
Thanks RonD, I will check These things
carfox
on GM trucks a flashing light would indicate that the front 4x4 differential solenoid has failed and your 4x4 capability, with it.
since there is noting to "lock" the differential with.
you need a new 4x4 actuator?
RangerJ
North Georgia
Just noticed that I forgot to update my post. I replaced the 4x4 control module and the problem was solved.
8,372
Thanks for the update
And good work :icon_thumby:
