5R55E Transmission interchange
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
that is what its looking like. 6r80 is better bet
they indicated to me you can turn the 2.3 mustang 4 cyl into a 4x4 version, which was previously described to me to not be possible...and not having had one apart of each i dont know.
so an updated 5r55e for now will have to do.
herpderp128
PA
Ranger XLT Ext
I hate to restart a thread that's almost a year old, but I think you guys may be able to help me. I have a 2002 4.0 Ranger with a dead 5r55e and have the opportunity to get a replacement pretty cheap out of another 99 4.0 Ranger. I've done some research, but I can only see people putting 01+ transmissions in 98-00 Rangers and mixed results answers regarding the other way around.
Will a 99 tranny work with the 2002 and will I need to do anything special wiring wise? I know it will physically bolt up and fit with the bell housing, but not what else may need done. I can get you guys any other details if you need. Thanks ahead of time!
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
The 99 is a 4r55e the 02 is a 5r55e. They are physically identical transmissions. Only the computer software is different. (The computer in the 02 truck has the ability to turn on overdrive while in first gear to make a fake second gear and giving it a total of 5 speeds)
The only issue with swapping between the two would be where the VSS sensors are. Some are on the differential, some on the trans. When they switched I have no idea...
