CAW
- Aug 12, 2007
- 0
Over the past week my truck has been having an issue which I can only assume is transmission related. When I drive at 50-60mph the truck will jerk several times, as if it is trying to shift gears and can't decide which gear to shift into. This only happens when shifting to a higher gear and not when slowing down from the problem speed range. The symptoms have been happening more often the last week. Sometimes the symptoms go away, or at least get better when the truck has been running for 5 or 10 minutes.
I am a bit of a novice when it comes to transmission work. I have checked the fluid level and it was full. The fluid and filter were changed about a year ago. The transmission code on my door sticker is "D" so I believe I have the 5R55E. I have heard that these can have problems with the valve body gasket blowing out? Another possible cause that I can think of would be a solenoid going bad. Perhaps the coil is effected by the vehicle warming up, making the problem intermittent. It always helps to get someone else's opinion. I would be totally open to any advice that you guys could give. Thanks!
1997 Ranger 4.0 OHV 200k miles 4x4
