5w-40 European oil in a 2.9?
Nez'sRanger
68
Pennsylvania
2.9L V6
Has anyone run 5w-40 European car oil in a 2.9? I'm currently running standard 10w-40 in mine, but the idea of 5w for cold starts sounds nice especially for winter. 40 weight seems to shut up the ticking nice.
Any reason not to? Thanks!
gw33gp
538
Costa Mesa, CA
4.0 SOHC
33"
I am running European 5W-40 synthetic in my 4.0 SOHC with no issues so far, but I have only been doing that since two oil changes ago.
I ran 20W-50 synthetic in my 2.9 for the whole time I had it which was almost 200K miles. Being in SoCal, I didn't have to be concerned about cold starts so much. When I did go to the mountains in the cold a few times, cold start was sluggish but always started. That oil was great for towing across our hot desserts.
The only negative thing I have heard of with the European 5W-40 is it used a higher amount of additives that can foul the catalytic converters. If you are not burning excessive oil, you should be fine.
19Walt93
4,483
Canaan,NH
351
3"
235/55R16
I'd run 5w30 or 10w30, 10w40 doesn't have the updated additives because the OEMs discontinued it long ago. In cold weather 20w50 would be like trying to pump jello.
